Re: M oil pressure question
Posted by Jim on March 31, 2001 at 08:26:28 from (198.247.178.213):
In Reply to: M oil pressure question posted by sprout on March 31, 2001 at 04:44:51:
Pull out your oil pump and check it out. Pull the cover off and them check for side clearance on the gear that is connected to the drive shaft. You will have to pull the other gear out to check the clearance.If you have over .010 side clearance I would replace the pump with a used one.
Post A Followup
: Re: Re: M oil pressure question
