Re: Dissapointing Hydro 100
Posted by Ace Schrunk on April 01, 2001 at 08:50:56 from (152.163.207.51):
In Reply to: Dissapointing Hydro 100 posted by Shepperd on March 31, 2001 at 16:20:02:
That is what one nver knows about used. could be motor could be the hydro could be as one said need to learn a little about using it. If that tractor is in good shape it will handle a good load you have to match the engine to the load it will not pull as much in high range as low if you think the hydro is not as good as it should be you need a flow rater to determen what it needs for repair maney times just a charge pump if the filter and oil have been kept clean they last a long time. my brother never thought he would like one till he got one then he wondered why he never got one sooner his son was the same way it may cost more to fix but they are a good tractor.
Post A Followup
: Re: Re: Dissapointing Hydro 100
