Re: Re: Re: Farmall C problem
Posted by Haas on April 01, 2001 at 12:00:50 from (129.37.117.90):
In Reply to: Re: Re: Farmall C problem posted by Tim on April 01, 2001 at 07:01:48:
Not unusual for there to be gas on the drain hole at the carb air intake. Happens when you use the choke. It's only a problem if the gas runs out all the time.
Post A Followup
: Re: Re: Re: Re: Farmall C problem
