Re: Re: Calcium wieght
Posted by Haas on April 01, 2001 at 17:03:09 from (129.37.117.35):
In Reply to: Re: Calcium wieght posted by pete on April 01, 2001 at 15:04:52:
I'm not sure what the standard calcium chloride solution for tractor tires is, but it weighs more than 8 lbs per gallon. The weight per gallon depends on the concentration of calcium chloride in the solution. I would think most folks would want to use a solution that would not freeze until at least 20 below zero. Such a solution would weigh 10.3 lbs per gallon and contain 2.6 lbs of calcium chloride per gallon of water.
Post A Followup
: Re: Re: Re: Calcium wieght
