Re: farrmall m
Posted by Chris on April 01, 2001 at 17:18:20 from (64.12.102.151):
In Reply to: farrmall m posted by roy on March 29, 2001 at 16:31:45:
Roy if you want to do it right,take the block out and bore it to fit the piston out of a farmall 450,the are 4 1/8", take the govenor apart and grind 1/3 of the wieght off the govenor wieghts, then take a small drill bit and make the high idle fuel jet larger in the carb. It all depends on the amount of money you want to spend.
have fun Chris
Post A Followup
: Re: Re: farrmall m
