Re: Governor on a farmall H
Posted by Farmer Bob on April 01, 2001 at 22:31:45 from (208.49.10.156):
In Reply to: Governor on a farmall H posted by John in AZ on April 01, 2001 at 20:31:34:
John, First off, do you have a service manual for the H? Sounds like the governor is not adjusted properly. Either your stops (inside the gov/) are off or the linkage from the governor up through the housing that connects the shaft to the carb is outa whack. With the tractor off, remove the angled cover with the small vent tube, you may have to loosen the tubeing nut on the other end of the tube where it screws into the head. Set the throttle to wide open, you should be able to twirl the connecting rod pin around with your fingers that connects the connecting rod coming up from the governor to the throttle shaft that runs horizontally into the carb butterfly. If you can't spin that pin, remove the small cotter key and the pin and lossen the nut on top of the connecting rod and adjust the horseshoe shaped adjusting block up or down so that when you pull both the connecting rod and the throttle shaft lever up as far as they will go you should be able to insert the connecting rod pin. The gov spring should not have any tension on it when the tractor is at idle (450rpm or so). Also check the bearing behind the fly weights inside the gov., it should not wobble on the shaft. Good luck.//FB
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
