Re: no spark on 1948 cub
Posted by Bus Driver on April 02, 2001 at 05:34:36 from (207.144.130.35):
In Reply to: no spark on 1948 cub posted by Glenn on April 01, 2001 at 18:17:47:
Your tractor most likely was equipped at the factory with a magneto. The "square" coil on top of the unit marks it as a magneto. When you bought the tractor, was the coil wire installed from the coil to the center of the cap where the plug wires originate? Has someone mounted another coil anywhere nearby? For testing the magneto coil, there is a procedure for using a multi-meter. If you can access any information on testing magnetos, the values shown on the meter may differ a bit from magneto model to model, but the basic procedure will be the same for all.
Post A Followup
: Re: Re: no spark on 1948 cub
