Re: Broken drain on C
Posted by gee on April 02, 2001 at 06:14:14 from (208.223.205.168):
In Reply to: Broken drain on C posted by FC on April 02, 2001 at 05:08:24:
What's worked for me in the past is to get a small chisel or stout screwdriver. Put it at an angle against the inside of the plug where the square recess is, like you would unscrew it, and use a small hammer to get it to unscrew. Hopefully you can tap it out. I would be afraid to try to weld something to it because of the heat involved.
Good luck
gee
Post A Followup
: Re: Re: Broken drain on C
