Re: Re: Compression on a H
Posted by john d on April 02, 2001 at 08:09:03 from (206.141.74.34):
In Reply to: Re: Compression on a H posted by The Red on April 02, 2001 at 03:57:32:
Use Red's numbers unless you have one of the "distillate-burners" with the extra little gas tank in front of the main one. In that case, you have a lower-compression head, and you'll probably not even come close to 110 psi unless it's been rigged with high-altitude pistons during its last overhaul! Something more in the range of 95-100 might be expected.
Post A Followup
: Re: Re: Re: Compression on a H
