Re: Farmall Super A 1950-1953
Posted by gene b on April 03, 2001 at 19:22:41 from (63.15.137.90):
In Reply to: Farmall Super A 1950-1953 posted by Labrador on April 03, 2001 at 13:15:52:
if you found a SUPER A with front and rear hy you have found a keeper they did not make such a thing better check and see what you were looking at you must have found something else if you knew anything about a SA you would know they didnot have a front and rear hy the hy system was a rockshaft type assy under the gas tank driven by a pump below the dist or mag which ever system it uses for ignition two tubes run back to the cast unit under the gas tank over the years things have been changed on all tractors but you do not have a front and rear hy system beetter know what you are buying as someone is selling something that does not exist you are not the first one that doesent know what you are getting into better get someone who is very informed on a SUPER A
Post A Followup
: Re: Re: Farmall Super A 1950-1953
