Re: B275 3pt lift
Posted by jimb2 on June 15, 2019 at 16:20:54 from (174.114.155.238):
In Reply to: Re: B275 3pt lift posted by MattW85 on June 15, 2019 at 15:45:38:
Hi, I tried to find the B275, B414, 434, 424 lift link lengths, all I could find was for 424 the lift link with the adjustable crank has a max length of 24" and Min length of 19 1/4".
So measure your lift link with the adjustable crank from where the pin is in the top to the pin in the lift arm.
I know the 54/74/84 series lift links are longer as we had a 684 and 434 and 384. The 434 and 384 were the same 3pt as your B275. One year it was very wet and we chopped corn with a JD 1 row 3pt hitch forage
harvester and the 684 3pt would not lift the forage harvester high enough to clear the mud so we installed the lift links from the 384 on the 684 and because the 384 ones were shorter the 684 was able to lift
the harvester high enough to clear the mud.
There is a poster on this site that goes by JDEM and he has several B275s so maybe he would be kind enough to give you the lift link lengths.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
