B Restoration Progress Pic
Posted by Red Raider on April 06, 2001 at 13:19:14 from (192.105.235.146):
I'm somewhere near the last part of a total B teardown and rebuild. At least the messy part of wire brushing rust is over. I can't believe the cost of seals that were replaced, and that's not including the ones in the overhual gasket kit. All that is left to purchase is a battery box, gallon of PPG AU and epoxy primer, and the rubber light fixture seals. The engine had been a '40 C-113 and now is a C-123 (3-1/8"). A small 4" freeze crack was found near the generator bracket mounting hole. It was insignificant and not leaking, but I chose to have the machine shop seal it with the drill, tap, and insert meethod (stitching). This week will be spent on the steering gear housing.
third party image
Post A Followup
: Re: B Restoration Progress Pic
