Re: low ash oil
Posted by Dellbertt on March 14, 2009 at 13:12:31 from (209.172.22.74):
In Reply to: low ash oil posted by CliffordPaul on March 14, 2009 at 07:47:26:
I have conventional plowed, disced, dragged and planted the same 40 acres since 1971 with JDA's and Farmall H's. I used the cheapest staight 30wt oil I could find. I never burnt a valve or rings, in fact I have never had to take a head off a tractor. They run smooth and do not burn oil.
I do not set the fuel too lean which is d*mned important.
I now have had 2 IH300U's for 10 years used for brush chopping and snowplowing and forklift. I run the cheapest 30wt. oil I can find and they both run excellant with great compression.
You can listen to all the hogwash theories you want on oils but I'm sticking to the way that's worked for me for 35+ years.
Dell
