Re: Re: Re: New Farmall Owner
Posted by Haas on April 08, 2001 at 04:41:56 from (129.37.117.159):
In Reply to: Re: Re: New Farmall Owner posted by Doc on April 07, 2001 at 19:48:04:
Yes, the seal on the pump input shaft. That shaft is connected to the pump gear. You should be able to take the cover off that is behind the belly pump under the tractor and see if the leak is coming from around the shaft. YOu can run the tractor as much as you want with the belly pump out. Won't hurt a thing. If you are into a lot of work with dirt, etc, would be good to put a cover over the opening in the clutch housing to keep dirt out of the clutch, etc. You can also just take out the coupling that drives the belly pump and leave the pump in there. To do that, you have to lower the belly pump down to get the "cross" piece of the coupling out.
Post A Followup
: Re: Re: Re: Re: New Farmall Owner
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
