Alcohol as a solvent to remove oil residue?
Posted by Lowell Davis on April 08, 2001 at 11:57:47 from (207.206.16.228):
I'm about to disassemble the hydraulics on my '46 M to fix leaks. I'm lucky to have live hydraulics - someone apparently retrofit the tractor with an M&W pump. I got a Loctite sealer specifically for hydraulic systems and want to make sure eveything is clean before assembly. Curtis van Fange wrote an article on solvents a couple of months ago that mentioned using alcohol to remove oil residues. What kind of alcohol? Isopropyl? Jack Daniels?
Post A Followup
: Re: Alcohol as a solvent to remove oil residue?
