Re: Re: char-lynn Pump? How to clean it for use?
Posted by Nate Danenberg on April 08, 2001 at 14:18:51 from (65.88.157.109):
In Reply to: Re: char-lynn Pump? How to clean it for use? posted by Les Repair on June 07, 2000 at 17:57:05:
Char-Lynn is an EATON Ind.item. Hydraulic pumps like cleanliness, but these pumps are very rugged. If you think it needs to be rebuilt, however, find a rebuild kit ($15.00 ?) from a supplier of Eaton parts. Rebuilding difficulty is a cross between a carberator and a distributer, and requires a mechanical sense and possibly some special tools. If you (or the previous owner) have dis-assembled the motor, it will need to be "timed", which is a careful lining up of parts during assembly. Follow directions.
Post A Followup
: Re: Re: Re: char-lynn Pump? How to clean it for use?
