Re: FARMALL M SLEEVES
Posted by Dan on April 08, 2001 at 14:25:42 from (12.18.158.25):
In Reply to: FARMALL M SLEEVES posted by DAVE on April 08, 2001 at 14:15:40:
the sleeves gl into a dry hoe in the block, would seem the only way it could leak water around the sleeve is if there is a crack in the block next to it.
Post A Followup
: Re: Re: FARMALL M SLEEVES
