Re: FARMALL M SLEEVES
Posted by Haas on April 08, 2001 at 14:57:13 from (129.37.117.176):
In Reply to: FARMALL M SLEEVES posted by DAVE on April 08, 2001 at 14:15:40:
The M has a dry sleeve. No direct path around the sleeve to the water jacket. You have either a crack in the cylinder wall behind the sleeve, or a corrosion hole. I'm betting its corrosion that has eaten all the way through from the water jacket side so that water is getting behind the sleeve. I'm not sure if this can be repaired or not. Others on the forum should be able to help with repair methods.
Post A Followup
: Re: Re: FARMALL M SLEEVES
