Re: Re: Re: Farmall M 12 Volt Conversion using a generator
Posted by rich on April 08, 2001 at 21:10:43 from (206.9.239.130):
In Reply to: Re: Re: Farmall M 12 Volt Conversion using a generator posted by Glenn (WV): Question on April 08, 2001 at 19:20:33:
I've changed a SM SC 300 to twelve volts Change the lights to 12 volt put in a resistor for the coil.One could wire up the soloniod for 12 volts while starting with a push button but it should (must) be wired so that it goes through a resistor for running. The starter does not have to be changed but the brushes may not last as long. really swings those engines over and twice as much light also the ground is positive.
Post A Followup
: Re: Re: Re: Re: Farmall M 12 Volt Conversion using a generator
