Re: Super A Hyrdaulic Remote Control Attachment
Posted by gene b on April 09, 2001 at 20:45:34 from (63.42.174.65):
In Reply to: Super A Hyrdaulic Remote Control Attachment posted by Terry H on April 09, 2001 at 16:37:37:
for the original I-H the tubes and fitting on the rockshaft housing are different you can use the original set up and remove the plugs that are in the casting that goes into the rockshaft run your lines to any two way control go from there a single spool valve can be used for a loader if you want two way hy use a two way control valve they are used both ways the tube assy from the pump that was used for the remote is quite expensive
Post A Followup
: Re: Re: Super A Hyrdaulic Remote Control Attachment
