Re: trans fluid farmall H
Posted by The Red on April 11, 2001 at 11:56:11 from (206.246.187.2):
In Reply to: trans fluid farmall H posted by Bruce on April 11, 2001 at 11:13:45:
Bruce use 90W or 85W140. If you are draining the system, it will take 6 gallons. There is the obvious drain plug in the rear. There is also a drain plug on the front of the transmission under the flat plate next to the liftall. That will drain about 2 quarts. Also if you have a flat belt pulley assembly, remove the 4 end bolts and tap that pulley out about 1/4 inch. You will get about 1/2 quart of 90W and WATER. The condensation in the transmission works it's way up into the flat belt pulley assembly. When you get ready to fill the transmission, save 1/2 quart and fill the flat belt pulley assembly. The fill hole is on top of the assembly.
Post A Followup
: Re: Re: trans fluid farmall H
