Re: Sealer for transmission drain pipe plug?
Posted by Haas on April 12, 2001 at 13:26:07 from (129.37.117.198):
In Reply to: Sealer for transmission drain pipe plug? posted by Lowell Davis on April 12, 2001 at 10:01:13:
I use Rector Seal No. 5. You can get it at the plumbing department at any building supply store. It is a Teflon emulsion, works just as good as teflon tape, and you don't have to worry about pieces of Teflon tape getting into anything and causing a stoppage. Of course that would not be a factor regards the transmission plug. Also with the Rector Seal, the threads will not seize up and it is easy to get things back apart.
Post A Followup
: Re: Re: Sealer for transmission drain pipe plug?
