Re: Super C float adjustment
Posted by FC on April 12, 2001 at 14:01:12 from (208.14.16.15):
In Reply to: Super C float adjustment posted by Dave T on April 12, 2001 at 13:10:23:
While I don't have the exact measurements, I set mine to be 'level' in relationship with carb body while carb was inverted and needle seated. This was per a IH mechanic who had done several. Seemed to work well for me. This was on a C with same carb (Carter UT). Someone will probably post exact measurement, but if not give this a try. I had a leak in float causing a problem and couldn't locate a float at the time. I punched a hole in it, drained, and resoldered. Working fine. Good luck.
Post A Followup
: Re: Re: Super C float adjustment
