Re: H - governor etc.
Posted by The Red on April 15, 2001 at 07:50:50 from (12.75.197.76):
In Reply to: H - governor etc. posted by John Rodwan on April 15, 2001 at 07:28:27:
John I emailed you some directions on the governor adjustment. After adjusting and you still have the load problem, I would suspect you will need a new governor spring.
Lead additive is not neaded for the H. They run fine on lead free 87 octane.
You will need a three prong puller to get the steering wheel off. If you are planning on replacing it, save your self some time and use a Sawzall or a hack saw and cut the steering wheel base where the key slot is at. You can then chisel the steering wheel base wider so you can pull it off.
C&G is an excellent source for quality parts. Ask for Ken Updike.
Post A Followup
: Re: Re: H - governor etc.
