Re: H radiator removal.........those @#%#* bottom nuts!
Posted by Farmer Bob on April 16, 2001 at 19:27:34 from (208.49.9.218):
In Reply to: H radiator removal.........those @#%#* bottom nuts! posted by Doug D on April 16, 2001 at 18:51:39:
Doug, Removing the frame rails will not help you. If the 6pt socket doesn't do the trick as Haas suggested, try using a universal with the socket. Last resort is the hacksaw option and replace the stud before reinstalling the radiator. Did you have to remove the cotter key in the castellated nut that is stuck?//FB
Post A Followup
: Re: Re: H radiator removal.........those @#%#* bottom nuts!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
