Re: Super C crank pulley
Posted by gene b on April 17, 2001 at 18:37:01 from (63.42.174.211):
In Reply to: Super C crank pulley posted by Tim - Maine on April 17, 2001 at 16:41:46:
make sure the set screw is out of the pulley some had one some did not usr a three jaw puller I USE A JACK AND PRESS THEM BACK clean all surfaces and oil them hammering is a good way to break them I made a bracket to press them one as I always seem to be working on them some go on easy and some harder that is why I PRESS THEM ON might take a little time to build a frame to press on with a hy jack BUT it takes time to find another one if you decide to hammer it use a good block of wood and be carefull not to break the cast good luck
Post A Followup
: Re: Re: Super C crank pulley
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
