Re: 1955 300U PTO will not shut off!
Posted by Charlie on April 18, 2001 at 06:20:21 from (209.130.148.186):
In Reply to: 1955 300U PTO will not shut off! posted by Dennis on April 18, 2001 at 06:05:47:
I've got a 300 U and had to do some adjustments on mine to fix the problem you are mentioning. The pto has the equivalent of a brake band to make it operate and a second one to hold it still when its not engaged. There is an adjustment bolt for each band. I'm not sure which bolt it is but you need to tighten the one that holds it when its not engaged. They are on the right, top of the pto unit. The worst case will be if the bands have gone bad - they are very expensive to replace.
Post A Followup
: Re: Re: 1955 300U PTO will not shut off!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
