Re: Help with Behlens Power Steering on '41 M
Posted by Dale13 on April 18, 2001 at 13:34:33 from (207.49.223.178):
In Reply to: Help with Behlens Power Steering on '41 M posted by Bama Red on April 18, 2001 at 11:48:19:
I believe that front seal is held in by a snap
ring,common prob is that once the ring pops out it
will not stay in. There is enough metal on each
side to drill and tap 1/4 20 bolts and washer to
hold the seal in. Take the seal # and you should
be able to get a new one thru NAPA.
Post A Followup
: Re: Re: Help with Behlens Power Steering on '41 M
