Re: Studs vs Bolts
Posted by big fred on April 18, 2001 at 14:02:31 from (12.13.226.15):
In Reply to: Studs vs Bolts posted by Dan on April 18, 2001 at 11:33:57:
Often you will find that studs have coarse threads on one end (into the casting) and fine threads on the other (where you put the nut). The torque requirements are different for the different thread pitches, so if you torque it to the same value, the clamping force and preload (which is what you are really after) would be wrong. You would also lose the alignment feature of the studs, i.e. you couldn't "hang" the head on the studs while you put the nuts on. I wouldn't do it myself, but if you adjust the torque value, it would work.
Post A Followup
: Re: Re: Studs vs Bolts
