Re: Help with Behlens Power Steering on '41 M
Posted by Jim on April 18, 2001 at 17:14:54 from (198.247.178.195):
In Reply to: Help with Behlens Power Steering on '41 M posted by Bama Red on April 18, 2001 at 11:48:19:
Ther is an O-ring in the end cap that is leaking all the seal is for is to keep the dust out of the O-ring from getting damaged by the dirt. To fix you leak you need to take the unit apart.
Post A Followup
: Re: Re: Help with Behlens Power Steering on '41 M
