Re: Re: Leaking Steering Box on C
Posted by FC on April 19, 2001 at 06:15:46 from (208.14.16.15):
In Reply to: Re: Leaking Steering Box on C posted by Haas on April 18, 2001 at 18:25:17:
Thanks Haas. When time permits I will dig into it. I hope it is not the pedestal seal, but there is so much oil on everything at this point it is difficult to tell. At any rate I will probably start with the shaft seal and bearing. There is quite a bit of play in steering, so I suspect a problem there as well. FC
Post A Followup
: Re: Re: Re: Leaking Steering Box on C
