350U hyd.line leak
Posted by Duner Wi on April 19, 2001 at 18:02:07 from (63.50.8.232):
The smaller of the 2 hyd. lines from pump to reservoir under seat is starting to leak at the plate that bolts to the reservoir. Is there a most correct way to repair this other than new lines. Weld, Braze,or tap it and run a hyd. hose.
Thank you!
Post A Followup
: Re: 350U hyd.line leak
