M carb problem
Posted by daniel g on March 07, 2009 at 08:24:21 from (209.163.124.253):
working on a m carb on a m tractor and with tractor running it would only run w/ choke on. Gas was also pouring out of the hole in the bottom. Pulled bowl off and found that there is supposed to be a plug of some sort in the bottom with a looks like a freeze plug drive in cap over it. I rebuilt one along time ago. Is it like a lead plug thing?? Not sure what you call it. Well anyway i need to figure out hoe to fix it. Cause its pulling air through this thing( hole about 3/8'' diameter) Does it come in a rebuild kit?
