Re: Replace engine
Posted by gene b on April 20, 2001 at 04:12:48 from (63.25.166.204):
In Reply to: Replace engine posted by Dan on April 19, 2001 at 16:59:08:
will work ok even the water pump will work IF you run the hy pump you will have to modify the steering shaft a little bit but no problem
Post A Followup
: Re: Re: Replace engine
