Re: Re: 12 volt conversion for Super A, Also IMPLEMENTS NEEDED
Posted by Tom Owens on April 20, 2001 at 18:14:30 from (166.102.50.88):
In Reply to: Re: 12 volt conversion for Super A, Also IMPLEMENTS NEEDED posted by Bob M on April 20, 2001 at 17:18:25:
Good article. I converted my A and was able to use the same brackets as the generator. Just turn the lower over 180 degrees and add about 4 or 5 washers to make it stand out enough for the belt to line up and the upper bracket will need about 1/2 inch or so spacer between the bracket and the alternator.
Post A Followup
: Re: Re: Re: 12 volt conversion for Super A, Also IMPLEMENTS NEEDED
