Re: Sputtering under load
Posted by Dave G on April 21, 2001 at 07:16:30 from (158.252.165.204):
In Reply to: Sputtering under load posted by Bill R on April 20, 2001 at 23:36:39:
I would first tune in the carb fuel mixture settings. Then do a timing check if the carb is not the problem. Might want to pull a gas line coming into the carb and check for good gas flow and clean out the carb. I don't think the governor is the issue.
Post A Followup
: Re: Re: Sputtering under load
