Re: Re: IH A (1948) need info leak
Posted by John on April 22, 2001 at 16:03:03 from (63.11.250.222):
In Reply to: Re: IH A (1948) need info leak posted by JOHN on April 22, 2001 at 05:36:22:
To Dave T (or anyone else);
I split my IH A to replace one of the frost plugs.
I fixed that problem. The water leak (just above the clutch) made a mess of oily goo. Prior to spliting the A the clutch wasn't fully working. None of the goo got into the clutch as far as I can tell. I have cleaned everything as much as possible without pulling the clutch completely off. There was a lot of debris (goo) around the bearing which I figure to replace. Any suggestions about the clutch itself? I don't want to split it again in the near future. I should also mention that the clutch was working great prior to the leak.
Post A Followup
: Re: Re: Re: IH A (1948) need info leak
