Re: Steering adjustment on 140
Posted by Haas on April 22, 2001 at 19:41:26 from (129.37.117.165):
In Reply to: Steering adjustment on 140 posted by Havin Fun in Mo on April 22, 2001 at 18:11:05:
No adjustments, but some things you can do to maybe tighten things up. Check all the tie rod joints for play. Check the big nut under the steering box that holds on the arm that goes to the tie rods. Sometimes that nut gets loose making play in that arm. Next is to check the worm gear bearing for wear. To do that, (drain the steering gear first) take the big plug with the big hex on it out of the front of the steering gear. You may have to remove the steering wheel, but I think there is enough room that you can screw out the worm gear far enough to check the bearing. Hold the front wheels so they can't move and turn the steering wheel and the worm should come out. If the bearing has any play, that can be a major contributor to steering play. The worm bearing is easy to replace and does not cost much. After these checks, you are into removal of the steering gear and major rebuild. However, this should be enought to get a good bit of the play out.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
