Re: 6 volt or 12 volt How can i tell w/o book?
Posted by The Red on April 23, 2001 at 08:59:10 from (206.246.187.2):
In Reply to: 6 volt or 12 volt How can i tell w/o book? posted by Pee Jay on April 23, 2001 at 08:54:35:
If your battery has 3 cells, it is 6 volt. If it has 6 cells, it is 12 volts. If you don't have a battery, see if there is a ballast resistor in the coil line somewhere between the switch and the coil. If not, it is probably still 6 volts.
Post A Followup
: Re: Re: 6 volt or 12 volt How can i tell w/o book?
