Re: Re: Farmall F-14
Posted by Tim on April 23, 2001 at 12:35:44 from (63.178.89.98):
In Reply to: Re: Farmall F-14 posted by F14 on April 23, 2001 at 12:02:55:
You're welcome Paul. I know Rice lists a Steering shaft coupling disk # 41281-D. Mine does not seem to have the knuckle that is pictured in my manual. Granted it's hard to tell because at this point it's a massive ball of weld. It appears to just have been two flat bars on the end of each shaft. Possible they were at right angles to each other and this disk was between them to act as a universal. Sound familiar to anyone? Also my shaft coming out of the gearbox is splined. Is that common?
Tim
Post A Followup
: Re: Re: Re: Farmall F-14
