Re: Re: Re: 1456 rear end problem
Posted by the tractor vet on April 23, 2001 at 21:25:37 from (216.196.12.72):
In Reply to: Re: Re: 1456 rear end problem posted by joe on April 23, 2001 at 10:19:24:
With out seeing the pices i am not sure more then likely you might have some bearings going bad or the carrier is starting to get chewed up this happen when running duals and doing a lot of sharp turning with the brakes the side gears start waring the carrier , time wise you are looking at around 16 to 20 hrs labor and may be 1000 to1500 in parts , now this is just a guesstamation but should be close. If you could get some used parts could be less as far as bolting a used housing on it well yes it can be done but would kill the value of a nice tractor , just my thought. I like to keep things the way they should be, YEA I AM A LITTEL NUTS gotta be to like tractors should have ben a doctor or lawer
Post A Followup
: Re: Re: Re: Re: 1456 rear end problem
