Farmall Tractors Discussion Board
Re: Farmall Cub--Oil Filter changing
Posted by Stan on February 08, 1999 at 14:40:24:
In Reply to: Farmall Cub--Oil Filter changing posted by Bill Swope on February 08, 1999 at 12:14:41:
Bill
I don't know much about a cub oil filter but I would guess it is similar to my super A. I just purchased it about a month ago and had a similar situation changing the oil myself. Posted a note here and the concensus of opinion was that I hadn't cleaned the grove where the canister gasket goes well enough. I'm not sure this was the only problem but it was definitely one of them. I also think I left too much oil on the base when I put the new filter on. Next time I change the oil I am going to try a filter from Case ( I bought a cheap one) and hope the gasket is just a little bit thicker. I also think getting it on straight the first time is an aquired taste. Hope this helps and good luck next time.
Stan
Post a Followup
: Re: Re: Farmall Cub--Oil Filter changing
