Re: Farmall A Final drive levels?
Posted by big fred on April 24, 2001 at 11:35:32 from (208.51.245.158):
In Reply to: Farmall A Final drive levels? posted by A-bob on April 24, 2001 at 09:59:28:
The level and fill plugs are the same plug. It is about an inch or so above the bottom of the final drive casting on the inside (toward the center of the tractor). I think it is a 1 inch pipe plug. Fill with 90W to that level. There is no drain plug, and the gasket surface is under the level of the oil, so make sure you didn't leave any of the pan bolts loose. It's a real good idea to replace the gaskets every time you change the final drive lube also, I think they were about $2.50 each at my Case/IH parts place
Post A Followup
: Re: Re: Farmall A Final drive levels?
