Re: got my 52 H home from PA
Posted by CNRed on April 24, 2001 at 13:52:39 from (205.188.193.29):
In Reply to: got my 52 H home from PA posted by Ron Barton on April 23, 2001 at 21:09:14:
Hi Ron. I have tried two other rust converters:
This is the website for POR-15:
http://www.por15.com/
I have also used Plasti-Cote's rust converter. It
is available at Advance auto parts stores (and
others). This person can offer advice if needed:
rmedley@valspar
So far both seem to work well. You remove loose
rust, clean the part, and coat it. It leaves a
black, plastic-like surface to paint on.
Good luck and have fun. I have only one H, but it
has enough projects to keep me busy whenever I
have time to work on it...............
Post A Followup
: Re: Re: got my 52 H home from PA
