Re: Re: Re: HELP!!! CUB PROBLEMS
Posted by p on April 25, 2001 at 08:14:06 from (131.210.22.124):
In Reply to: Re: Re: HELP!!! CUB PROBLEMS posted by Mike Johnson on April 25, 2001 at 07:27:15:
when you have the inspection plate off you should also check valve clearances. Any good manual will walk you through the steps and have the tolerances. If the engine is not smoking and the spark plugs are not developing deposits, then I would suspect the valves are shot. If you have been running unleaded fuel without a lead substitute then you may have destroyed the valve seats. The seats are not hard enough for modern gasoline. If you were running the motor hard the seats will heat up and small amounts of metal will stick to the valve and remove itself from the seat. This will cause pitting on the seats and eventually result in lower compression. I don't think pulling the head and lapping the valves will do enough to clear this up. The block will have to be machined to accept new hardened valve seats. At this point it only makes sense to do a quicky rebuild to ensure proper ring pressures. I have heard that adding a few squirts of oil to each cylinder before performing a compression test will help diagnose worn rings. I heard that if the pressure increases after the oil is added if proves a bad ring and bore fit. The oil fills the voids left due to imperfections. I have not tried this but it makes sense. let us know what you find.
Home
| Forums
Today's Featured Article -
A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
