Re: Re: Re: cub won't speed up
Posted by Bob M on April 25, 2001 at 11:32:42 from (192.232.119.194):
In Reply to: Re: Re: cub won't speed up posted by Pat on April 25, 2001 at 10:24:45:
If you partially close the choke will motor run better - even if just for a few seconds? If so your problem is restricted fuel flow. To remedy proceed as follows: 1 - Remove the fuel line at the carburetor, then open the shutoff at the sediment bowl. You should get a solid stream flowing out the end of the line - not just dripping gas. If you don't, clean the sediment bowl screen and check for an obstruction in the shutoff valve. Also check for junk in the opering where the sediment bowl screws into the tank. 2 - If you see good fuel flow, the problem's an obstruction inside the carburetor - most likely something plugging either the float valve or the high speed metering jet. Disassemble the carburetor again and throroughly clean everything inside. Check and clean the screen (if there is one) behind the fuel inlet nut. Blow out all internal passages with compressed air before reassembly. Check for proper float level and make sure the float is not binding before installing the float bowl. Good luck!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
