Re: Re: Re: HELP!!! CUB PROBLEMS
Posted by Bill {Antique Acres} on April 25, 2001 at 12:01:35 from (63.162.254.60):
In Reply to: Re: Re: HELP!!! CUB PROBLEMS posted by Mike Johnson on April 25, 2001 at 07:27:15:
You do not have to remove the manifold to get the cover off. I also failed to mention that the fuel supply from the tank to the cylinders is extremley important on these Cubs. I would first make sure to find out why those 2 cylinders are so low. After that I would make sure that you have good fuel supply to the carburetor and that the carburetor is good and clean. Your readings should be all within 10 pounds or so from each other. all four at 80 would be on the low side, but it would still run. The last 2 are right up where they should be, but 1 is way off. Check the valve clearences and make sure everything is opening and closing. You could have developed some bad seats in the top of the block also. When you check your readings again make sure you have the throttle wide open and the choke off. Bill {Antique Acres}
Post A Followup
: Re: Re: Re: Re: HELP!!! CUB PROBLEMS
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
