Re: Re: Re: HELP!!! CUB PROBLEMS
Posted by Havin Fun in Mo on April 25, 2001 at 16:27:15 from (64.196.152.3):
In Reply to: Re: Re: HELP!!! CUB PROBLEMS posted by Mike Johnson on April 25, 2001 at 07:27:15:
The advice that "p" offers below is good. The trick he mentions is a real easy way to determine the cause of a leak. A couple of squirts of oil is enough to fill the gap of worn/weak rings but will not fill the gap of worn/burnt valves. This can be done in a few minutes without having to take any major components off the engine. Be sure to work quickly after inserting the oil and only let the motor crank a rotation or two if possible as the oil will disperse.
Post A Followup
: Re: Re: Re: Re: HELP!!! CUB PROBLEMS
