Re: Re: IHC 784 Tractor D246 Diesel Motor (German Motor)
Posted by Brian M. Bideau on April 26, 2001 at 07:23:29 from (216.96.37.138):
In Reply to: Re: IHC 784 Tractor D246 Diesel Motor (German Motor) posted by Les Repair on April 25, 2001 at 17:37:14:
The tractor did have a replacement sleeve and piston kit put in it, no otherway to do the overhaul that I know of. The valves and seats were also grownd. A lower compession ratio I could believe. Could you elaborate (explain) a little more on the "been there - done that" comment? Do you mean that you had a tractor with this exact same problem? What did you do and how did you do it? My local Case/IH dealer says that they did all they were supposed to do and that the tractor is fine? Is there a means to check the compression in the cylinder without taking the injector out?
Thank you
Post A Followup
: Re: Re: Re: IHC 784 Tractor D246 Diesel Motor (German Motor)
