Re: Adjust float on cub?
Posted by Bob M on April 26, 2001 at 15:49:41 from (66.66.72.246):
In Reply to: Adjust float on cub? posted by Pat on April 25, 2001 at 19:39:54:
Pat - Carefully bend the metal piece between the float body and the pivot (hinge) pin. Distance between the bottom of the float and the top edge of the float bowl mating surface should be 1-11/32" (this is with the float valve shut).
Post A Followup
: Re: Re: Adjust float on cub?
